advice on trans service
With that low of miles, you should be good with just a pan drop and filter change or a flush if you so choose. Unless the fluid is burnt, you should not really have to do a flush. While the pan is off, install an add-on drain plug and you will never have to pull the pan again. Remember, the only thing to plug up a transmission filter is the transmission parts themselves!
B&M makes a pretty good add on drain plug. Just drill a hole and install the plug. I use red loctite on the jam nut used to make sure that it does not come loose. This will add some time, but good insurance against having to drop the pan again.
turbowubz
Feb 9, 2014 08:42 PM
smg614
Jun 21, 2011 12:13 PM
Thrillhouse
Nov 23, 2009 03:45 PM
