advice on trans service
Old Jan 18, 2009 | 12:39 PM
ziggy123's Avatar
ziggy123 is an unknown quantity at this point
Default advice on trans service
can anyone give advice on service for a 99 auto with 67000 miles?have heard horror stories on the new fluid wasting clucthes.is ther a good additive to prevent this?thanks
Old Jan 18, 2009 | 01:14 PM
Default RE: advice on trans service
With that low of miles, you should be good with just a pan drop and filter change or a flush if you so choose. Unless the fluid is burnt, you should not really have to do a flush. While the pan is off, install an add-on drain plug and you will never have to pull the pan again. Remember, the only thing to plug up a transmission filter is the transmission parts themselves!
Old Jan 18, 2009 | 09:04 PM
ziggy123's Avatar
thanks for the feedback,do they seel the plugs for the old pan or do you have to get a new pan?Also are they easy to obtain?
Old Jan 19, 2009 | 06:53 AM
B&M makes a pretty good add on drain plug. Just drill a hole and install the plug. I use red loctite on the jam nut used to make sure that it does not come loose. This will add some time, but good insurance against having to drop the pan again.
turbowubz
Feb 9, 2014 08:42 PM
dpmeeks
Sep 29, 2013 07:10 AM
drummerdude84
Jan 29, 2012 09:54 PM
smg614
Jun 21, 2011 12:13 PM
Thrillhouse
Nov 23, 2009 03:45 PM
