ATF - To Change or Not to Change
Old May 10, 2012 | 10:36 PM
Hormisdas's Avatar
Hormisdas is on a distinguished road
Thank you. Thank you. Thank you! I think I'll go with the $160 flush and fill. Then if the whole filter thing REALLY bothers me I'll buy the GM part and do it myself. If I decide to do that, is it okey for me to put the same "new" fluid back in after I replace the pan?
Old May 11, 2012 | 01:02 AM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
I don't see why not as long as the fluid looks clear, clean and doesn't smell burnt.
Old Nov 27, 2012 | 07:15 PM
Roberto Lavin Lopez's Avatar
Roberto Lavin Lopez is on a distinguished road
Hi, I had a question. According to GM, in my country, tranny oil change is just the oil pan volume (6 to 8 qts) plus oil filter per 25k miles (40k km). If know tranny had 135k km, and the last "oil change according to GM was around 80k km (50k miles), it is dangerous to perform a total flush or just perform a 66% flush know (10 qts) and next 25k miles do a total flushing?
PS 10 qts flushing because MAG ATF dexron III sales here in 2.5 gallon format an it is a lot cheap than buying 8 qts bottles...
Old Nov 27, 2012 | 07:37 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Never flush it it can break loose sludge and make problems, just do a filter and then refill!
Old Nov 27, 2012 | 07:47 PM
Ok, but the refill volume is near to 6 o to 10 Qty?. GM service says 8 Qty (it had a deep pan... but...)
Old Nov 27, 2012 | 09:42 PM
Joshs4x4's Avatar
Just watch the dipstick! Remember to check ATF it needs to be at normal operation temp in neutral and on a flat surface.
ABSLT
Dec 15, 2011 01:16 AM
TomSawyer
Feb 25, 2010 05:55 PM
BlazinJay84
Jan 25, 2008 07:50 AM
vassago41301
Jan 26, 2007 03:58 AM
acarlson
Jul 19, 2006 01:09 AM
