dist cap
Old May 26, 2008 | 08:54 PM
scott96's Avatar
scott96 is an unknown quantity at this point
Default dist cap
took the dist cap of my 96 4.3l blazer yesterday, the terminals looked like they were oxidized cleand them up and not it runs like crap. did i do something wrong?
Old May 26, 2008 | 08:56 PM
WolfPack's Avatar
Default RE: dist cap
shoulda replaced the cap/rotor.
Old May 26, 2008 | 09:01 PM
scott96's Avatar
is it bad when it is oxidized?
Old May 26, 2008 | 09:09 PM
Carbon build up on the terminals will cause misfires. Cleaning a cap/rotor will not fix the problem, you must replace these components. Reason being, cleaning often results in removal of more than just the built up carbon. Changing the gaps in the ignition system will cause more problems than you originally had.
With ignition components, do not go cheap! Quality components cost a bit more.
Old May 26, 2008 | 09:21 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
You can get the acdelco cap and rotor on rockauto fairly cheap. By cleaning it you basically did the equivalent of plugging something in just enough so it arcs but not enough so it works right.
LannyL81
14
Mar 4, 2013 05:21 PM
crater
Nov 1, 2011 03:57 PM
01bluerado
Sep 1, 2011 10:40 AM
r6thor
Jan 5, 2011 11:36 AM
fnirish
Oct 24, 2006 02:02 AM
