engine swap ?
i have a 87 blazer 2wd with a fried 2.8 was thinking about doing a 350 swap,i would like to go carb, will i have to change the fuel pump/tank?do i need to get aftermarket motor mounts,will the driveshaft work or will i need to get it shortened? its just going to be a daily driver for now. i appreciate any advise you guys have. thanks.
check out http://www.jagsthatrun.com/ everything you need to know about a v-8 swap
Problem is the 2.8 is a different engine setup than the 4.3. The reason everyone goes for the 350 is because it bolts right up to a 4.3 truck.
Pretty sure from the 2.8 platform, the direct swap is the 305 v8. To go with a 350 you need a new transmission, and I have no idea if the mounts will even match up with the engine and tranny..
the bolt pattern for the bellhousing differs between 2.8 and 4.3. The 305 and 350 are physically identical except for the bores. so if you have a 2.8 truck you need to get a new trans and driveshaft. the jagsthatrun website is very helpful. good luck with your swap
ORIGINAL: flip469
gmoney30
Jul 5, 2010 08:51 PM
gmoney30
Jan 22, 2010 07:07 PM
