engine swap
Old Jun 23, 2009 | 02:15 PM
bmxer938's Avatar
bmxer938 is on a distinguished road
Default engine swap
I'm gettin ready to pull a 4.3 out of a 95 blazer 4wd and put in another 4.3 out of a 96 jimmy 2wd. they look like different motors and i need to know if they'll swap easily
Old Jun 23, 2009 | 07:10 PM
bravadaAWD's Avatar
bravadaAWD is on a distinguished road
i'm pulling my engine out of my 1998 bravada and replacing it will a 2003 silverado 2wd engine. swapped the manifolds, intake, oil pump, oil pan, knock sensor. and i will have to say pulling the engine without the trans was a pain in the ***! i should of pulled the trans with engine or pulled the body off and did it that way. good luck i have some pics i post later.
Old Jun 23, 2009 | 07:37 PM
You should be able to use the short block, but the heads on up are different on the 96+ SCFI motors when comparing them to the 95 and earlier CPI motors.
Old Jun 25, 2009 | 03:12 PM
bmxer938's Avatar
will the 95 heads bolt up to the 96 block?
gmoney30
Jul 5, 2010 08:51 PM
SureShooter29
Mar 18, 2010 03:02 PM
gmoney30
Jan 22, 2010 07:07 PM
ronnyrum1
Engine & Internal
Dec 11, 2005 11:34 AM
billybird
Jul 20, 2005 11:17 AM
