Flywheel to torque converter problem
Old 03-26-2012 | 05:34 AM
coolasice's Avatar
coolasice will become famous soon enough
Originally Posted by Newblzrowner
So I figured out the problem. The pistons are binding. I took them out and tryed each in A cylinder and 3 fit and the fourth is binding in all 3 remaning holes? Any advise?
did you measure your cylinders and bores? did you check ring gap?
Old 03-26-2012 | 04:59 PM
Newblzrowner's Avatar
Newblzrowner is on a distinguished road
I did not but would that make them bind?
Old 03-27-2012 | 05:26 AM
coolasice's Avatar
it can, and it can ruin the rings. Did you install new rings?I f you didn't, then you somehow got pistons mixed up, which means now's the time to put new rings, were the cylinders honed? Be sure to gap rings relative to each cylinder they will go into. The ring manufacturer should have specs to use for that.
Old 03-30-2012 | 07:09 PM
UPDATE: The bearings were oversized. Autozone since made it right with a $60.00 credit, case of wrong part right box....
project 96
03-22-2010 01:58 PM
killallblue
10-27-2009 02:14 PM
blackhole79
09-04-2006 01:40 AM
Canadian88
02-13-2006 04:04 PM
blazerrick
14
12-28-2005 09:07 PM
Quick Reply: Flywheel to torque converter problem
