Found an oil leak - quick question
Old Jan 11, 2017 | 06:40 AM
mech cb's Avatar
mech cb is on a distinguished road
Default Found an oil leak - quick question
I had to replace my oil pressure sending unit recently, and of course I had to pull the distributor to get to it. When I pulled the distributor out and I was looking it over, I knew I needed to replace the o-ring, but didn't have one on hand. It's been in that engine for over 200,000 miles now and I just knew it wouldn't seat right when I put it back in.
Sure enough, everything is back together and my distributor is leaking oil. The auto part stores are telling me I can't just order the o ring by itself, so here's my question. The o ring currently has flat sides - I assume from being pressed into place for so many years. Will a general o ring work to put back in it's place or do I need a special o ring of some type? I've got access to an o ring kit that I was thinking about using, but I can't find any pictures of the original o ring. If it is a special type of o ring, can anyone point me in the right direction?
Old Jan 12, 2017 | 08:52 AM
LesMyer's Avatar
It's just a flat circular gasket, not an o-ring. Felpro 70194. Any local auto parts store should have this.
Old Jan 12, 2017 | 11:35 AM
rockp2's Avatar
Old Jan 19, 2017 | 06:29 AM
mech cb's Avatar
Thanks y'all
ComputerNerdBD
Mar 20, 2013 12:33 AM
BubbaBrooks
May 18, 2011 08:38 PM
TimmyBlaze
Dec 23, 2010 11:01 PM
TAZ454
Jan 28, 2008 10:11 AM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
