Freakin Frustration!
Old Oct 6, 2014 | 06:47 PM
Lisa Nixon's Avatar
Lisa Nixon is on a distinguished road
Question Freakin Frustration!
HELP! Bought a 97 Chevy Blazer that had been sitting for 3-4yrs due to bad fuel pump and laziness. Replaced fuel pump and it fires right up. But when I shift into R or D it dies. If it doesn't die when shifted it will when you apply the brakes. TCC solenoid, maybe? Torque Conv stuck in lock up? Ideas... anyone?? Thanx
Old Oct 6, 2014 | 07:55 PM
rexazz2's Avatar
does pressing the brakes effect the idle when in park ??
I ask because I am thinking vacuum leak ,power brakes takes away vacuum
Old Oct 6, 2014 | 11:45 PM
Lisa Nixon's Avatar
Talking
Yes, pressing the brakes takes rpm's way down but it comes back up slowly if it doesn't die. How do I check for vacuum leak with the breaks? I am kind of new at this. Thanx
Old Oct 7, 2014 | 10:43 PM
cleburne red's Avatar
I bet you could probably rule out a brake related vacuum leak by disconnecting the brake booster, and plugging the vacuum hose to it. you won't have power assist, but the brakes will still work. If your problem goes away, time for a new brake booster.
Lisa Nixon
Feb 13, 2015 11:11 PM
Mike98Blazer
Nov 6, 2011 10:25 AM
shotnva777
Oct 13, 2011 09:53 PM
JRob238
Feb 5, 2010 05:02 PM
krisg
Jan 7, 2010 10:27 PM
