Frustrating Problem
Old Oct 23, 2011 | 06:52 PM
Clyde's Avatar
Clyde is on a distinguished road
bump?
Old Oct 23, 2011 | 09:54 PM
trucktom's Avatar
trucktom is on a distinguished road
the gas smell is normal as well as the carbon levels. egr always dumps more on one side and makes it dirtier. a wet leak will clean a spot to a shine. its hard to see by the pic, so have lines hooked up, cycle key a few times to prime. if u c fuel anywhere, it shouldnt be there. those 2 big fuel feed lines are know to crack and leak too. did u check some sensors first? and u need to check the egr valve itself. unbolt and push the plunger in, it should jump back out nice and smooth and close all the way
Old Oct 25, 2011 | 10:28 PM
jpalen's Avatar
jpalen is on a distinguished road
you can connect the fuel lines and the connector for the injextors and turn the key on with the upper manifold off and look for a leak. I had one on my 96. needed a new regulator.
Jim
96realwe
Dec 10, 2010 09:19 AM
English5
Jul 16, 2010 11:11 AM
Cavalier z24
Mar 9, 2010 09:35 AM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
