fuel pressure problem
Old Mar 4, 2009 | 01:35 PM
kpianka's Avatar
kpianka is an unknown quantity at this point
Default fuel pressure problem
my 95 blazer is having problems i cant put alot of pressure on the gas peddle other wise the truck will stall. they did a pressure test replaced wires,rotar,and cap can anyone explain what might be wrong before i have to replace the spider which is big money.
Old Mar 4, 2009 | 02:33 PM
What were the results of the pressure test?
Try removing the pre-cat O2 sensor completely from the vehicle and see if it runs any better. If it does, then your catalytic converter is plugged.
Old Mar 5, 2009 | 06:48 PM
kpianka's Avatar
Default ill try it
thanks for the input ill let u know
racinghoss
Sep 10, 2023 08:56 PM
Bad Ramer Jamer
Sep 16, 2008 10:32 AM
Spartan66
Jul 11, 2008 02:34 PM
gpr13902
Apr 29, 2008 10:12 PM
adlady
Aug 26, 2007 01:35 AM
