Fuel Pump Fuse
Old May 25, 2011 | 12:27 PM
cmc039's Avatar
cmc039 is on a distinguished road
Default Fuel Pump Fuse
I have a 2002 blazer, and the other day it wouldn't start. I checked the fuses and the fuel pump fuse had melted. I took the DRL fuse out and put in the fuel pump fuse slot and it started right up. I drove it a couple of miles and checked the fuse and it was extremely hot. Could a bad fuel pump cause the fuse to overheat and melt?
Old May 25, 2011 | 03:41 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
more along the lines of a short somewhere making things difficult. Sometimes two wires will touch and rub through and start a short. If on the other hand the pump is semi clogged and it is working alot harder then it should it would be like putting a heavier load on a motor then it can take. Dig around first with a DMM first before you rip out the gas tank.
Old May 28, 2011 | 09:22 AM
cmc039's Avatar
I'll try that first. Thanks.
Old May 28, 2011 | 09:29 AM
jackdough's Avatar
jackdough is an unknown quantity at this point
might want to look at a post on here by rifleman. he has a good thread about cleaning up the ground for the fuel pump. its linked into a splice pack and grounds a few things, but i was having some pretty serious issues with my pump, and since i fixed that its been fine. i think the post is called "finally found my problem"
BouncingRadical
14
Nov 27, 2015 12:30 AM
Joann
Oct 14, 2013 10:33 AM
AustinBlazer
Jun 4, 2013 10:35 AM
celchlepp
Nov 18, 2008 11:16 AM
oldsmobuick420
Nov 19, 2005 04:30 PM
