grinding gear noise right below center console...
Old Aug 18, 2008 | 07:56 PM
watsonracingteam's Avatar
watsonracingteam is an unknown quantity at this point
Default grinding gear noise right below center console...
1998 4WD Blazer.
Soon after starting the truck you will hear a grinding noise like gears are working at getting into their correct locations, right below the center console.
No matter the speed of the truck the speed of these gears getting the correct position will stay the same, not speed up or slow down. I have even put the car into neutral, rolled along and revved the motor, same noise.
I think the 2WD & 4WD are vacuum actuated? Do not know if this noise is related to that. Truck needs to sit a few hours or more before it will do it again.
If I let it idle for a bit it does not do it.
Any ideas???
Brian 267-516-0305
Old Aug 18, 2008 | 08:41 PM
Default RE: grinding gear noise right below center console...
Have a look under hood at the throttle and cruise control cables. Make sure that they are not resting against anything on the driver side of the engine. Specifically the PCV valve tube that runs up to the lower intake manifold from the driver side valve cover.
Old Aug 25, 2008 | 04:03 PM
Dealer said it was the vacuum actuator, used to lock front axel hubs in and out of 4 wheel drive.
matthewp
Apr 4, 2021 09:16 PM
Heffty
Mar 22, 2014 09:00 AM
1911cdp
Jul 31, 2010 02:00 AM
k5009
Jul 19, 2010 12:34 AM
bigal04
Oct 3, 2007 06:10 PM
