Help
Old May 6, 2021 | 12:42 PM
Dizer Capps's Avatar
Dizer Capps is on a distinguished road
Default Help
Dropped bolt in distributer hole (not me) then lost magnet. I seen the boats next to the oil pump down in the hole then it was gone never seen the magnet I seen it stuck to the side somewhere I have a scope with a light camera unable to locate I was told pull the pan off that's a job in itself hoping for some help
Old May 6, 2021 | 12:45 PM
Default Help
Sorry Newby first time 03 blazer from Missouri
Old May 6, 2021 | 02:11 PM
A bolt sitting on the bottom of the pan probably won't ever cause you any problems. It can't get sucked up in the oil pump pickup screen, and it's too far away from the crankshaft to be very likely to get caught in it. The magnet, on the other hand, if you don't know where it is, can get jammed up in the distributor drive gear or someplace else and ruin your day. If it were mine, I'd pull the pan and remove them both. But if you're a gambler, you can roll the dice.
*EDIT*
If the bolt is in the distributor hole by the oil pump drive shaft, it definitely needs to come out.
Old May 6, 2021 | 05:24 PM
*EDIT*
it was like between the the wall and the part that sticks up in the center I seen it with my own eyes I got down when I came back it was not there somebody else had been trying to get it out to no avail I never seen the magnet but the screws gone on the boat is gone I don't know where it could have went from that position I've got a digital scope I'm sticking in to see if I can find it no luck so far. I'm going I'm going to insert the camera but in the oil field drain hole and see if I can see anything in the bottom of the pan
Old May 7, 2021 | 11:23 AM
*EDIT*
ran a scope in the pan could not find bolt or magnet don't know where to look. I guess I should start by taking intake off???
Old May 7, 2021 | 11:27 AM
Probably, unless you can see in there with the camera through the distributor hole. It's not a terrible job to remove the intake, and it's an "opportunity" to upgrade your lower intake manifold gaskets if you haven't already. Make sure you buy the Fel-Pro metal ones. Sorry, I don't have the part number handy.
Hopefully, you'll find the bolt and the magnet in there.
Old May 11, 2021 | 10:54 AM
Removed intake upper an lower no luck on finding bolt was able to run the scope a little further down. Standing at the front of the truck looking at it the back left hand side of the distributor hole I believe I found the boat at the bottom left I guess my next alternative is to drop the pan help
Old May 11, 2021 | 11:13 AM
Well, that sucks. If the pan were steel, I would cut a hole in the bottom of it, remove the bolt, and weld a patch on it. But cast aluminum is much harder to weld properly. Maybe turn the truck upside-down and shake it, lol?
Sorry I don't have any better answers for you. Maybe you can drop the pan enough to fish it out with a magnet so you don't have to remove it completely?
JRT
Mar 27, 2019 03:46 PM
livetrapper13
Feb 23, 2018 08:55 PM
DT727
Dec 25, 2011 09:19 PM
gibson_es
Oct 20, 2010 08:02 AM
andrea
Jul 15, 2009 09:51 AM
