Help, tranny question
Old Oct 15, 2008 | 07:46 PM
chosenone23v's Avatar
chosenone23v is an unknown quantity at this point
Default Help, tranny question
I recently bought a '96 4x4 (push button)Chevy Blazer with a 4.3L vortecand 4L60E. The 4.3 was supposedly bad. I pulled it and replaced it with an '83 carbed Chevy 350. I know the tranny won't work now since it's computer controlled (it's a two piece bellhousing). What year 700R4/4L60 tranny can I bolt up to the transfer case or will I need to find a new transfer case as well.
Old Oct 16, 2008 | 09:11 PM
Default RE: Help, tranny question
ttt
Old Oct 17, 2008 | 03:55 AM
Hanr3's Avatar
how many bolts between the t-case and tranny adapter?
The older t-case had 5 and the newer have 6. You will need a t-case with 5 bolts to mount up to the 700R4/4L60 tranny. OR you might be able to swap your currenttranny/t-case adapter and make it work just fine? Contact Advance Adapter, they are the experts in mating t-cases to trannies.
Old Oct 17, 2008 | 09:09 AM
Thanks for the reply Hanr3. There are six bolts between the adapter to the t-case. I need to use a newer style t-case since the 4x4 is push button. I'll check out Advance Adapter too.
Old Oct 17, 2008 | 07:07 PM
Oops, just went out and double checked the number of boltsand there's six bolts that bolt to the tranny and five that bolt to the t-case. Sorry!
ski.dive
Feb 7, 2014 05:18 AM
Logan
Jan 21, 2010 09:07 PM
xtreme03
Engine & Internal
Sep 30, 2006 06:25 PM
tomsblazer
Aug 21, 2006 01:01 PM
jagblazer01
Mar 1, 2006 10:29 PM
