Help, tranny question
I recently bought a '96 4x4 (push button)Chevy Blazer with a 4.3L vortecand 4L60E. The 4.3 was supposedly bad. I pulled it and replaced it with an '83 carbed Chevy 350. I know the tranny won't work now since it's computer controlled (it's a two piece bellhousing). What year 700R4/4L60 tranny can I bolt up to the transfer case or will I need to find a new transfer case as well.
how many bolts between the t-case and tranny adapter?
The older t-case had 5 and the newer have 6. You will need a t-case with 5 bolts to mount up to the 700R4/4L60 tranny. OR you might be able to swap your currenttranny/t-case adapter and make it work just fine? Contact Advance Adapter, they are the experts in mating t-cases to trannies.
ski.dive
Feb 7, 2014 05:18 AM
