Help with a trans
Old May 27, 2011 | 06:51 PM
garryb's Avatar
garryb is on a distinguished road
Default Help with a trans
i need to know what is the easyes way to remove the bolts from the trans to the engine? i am going the rplace the sun shell and the sungear with the large bushing and the seals.i also need to know if there is any tool that i have to have that someone would not normaly have. and is there any way to get the spring packs out with out useing the tool for that, or can you just push down and remove the snap ring? thanks for any and all help. garry
Old May 28, 2011 | 07:29 AM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
i went on youtube and found how to's and just searched the web and found info on making your own tool and where to buy the tool. but i decided against it and got a rebuild from Monster Transmission
Old May 30, 2011 | 08:47 AM
TZFBird's Avatar
TZFBird is on a distinguished road
You might as well do a complete rebuild because it requires taking pretty much everything apart anyway. Make sure you have a book and read through it 3 times before you even start. You will need at minimum some transmission snap ring pliars($25). I'm not sure what all you are replacing exactly.
If you are going to be working on anything with springs, I made my own compressing tools out of 1/4" thick 1" wide steel and some All-Thread. Just get creative and figure out a way because plan on $100+ for just about any tool you need to work on a transmission.
ksunday1
Nov 5, 2013 02:22 AM
m.sterner
Nov 29, 2009 10:34 PM
86blazeder
Feb 24, 2009 07:33 PM
luthers97blazer
Nov 10, 2008 01:27 PM
rob1621
Feb 29, 2008 08:15 PM
