Help with Trans Rear Seal
How in he world does a person change the rear output shaft seal in a 1997 Jimmy 4whl drive?? I have the 6-8 inch think piece that bolts on to the rear of the trans (held on by 5 bolts) off. But I see no way to get in there to get that seal out...I cant really even see a seal.. I'm not familar with these vehicles just helping a buddy out. Any help would be great,
The problem is the vehicle is dripping a little fluid from between the tranfer case and the trans...read that its probably this seal. The transfer case was overfull as well.
Thanks
Thanks
Thats kind of what I though, as I couldnt find a seal to purchase anywhere... but there seems to be some confussion by myself.. and othes I have read on other message boards. Why was the transfer case overfull. Some say factory does it. Others say it leaking in from the transmission..Like I said these vehicles are new to me so Im trying to fiqure things out..
Thanks again.
Thanks again.
So if I understand everything correctly when the transfer case and the transmission are connected the transfercase front seal also acts as the transmission rear seal as well? That could explain why the transfer case was overfull? Is this what goes on in these vehicles?
Thanks
Thanks
litterbug
Mar 7, 2011 09:14 PM
ccyne
Mar 20, 2009 07:00 AM
