Identifying a 4.3L Vortec
Old Dec 14, 2012 | 06:27 PM
alex52e's Avatar
alex52e is on a distinguished road
Default Identifying a 4.3L Vortec
A buddy of mine just gave me a 4.3L Vortec engine and trans with about 45k miles on them. They came from a Blazer that had been wrecked and had frame damage. It struck a tree broadside so there was no damage to the engine or trans. He wasn't sure if it was from a 1994 or 1996 Blazer. How can I determine which one it was and what it will fit into? I got it (free) with the intent of finding a cheap vehicle (probably with a blown engine) to put it into for my daughter. Any help would be appreciated.
Old Dec 14, 2012 | 06:45 PM
Diaita's Avatar
google vortec. the 2 have very different intake runners.
Old Dec 14, 2012 | 06:50 PM
xgiovannix12's Avatar
If it has the flat distributor cap its from a 95 + if it has the cap with the terminals on top its from a 94 down
Old Dec 15, 2012 | 05:47 PM
This is a mid production 1995 "W" engine and older:
This is a late production 1995 "W" engine and newer:
Without some serious modifications, they are not interchangeable.
Attached Thumbnails Identifying a 4.3L Vortec-cmfi.jpg   Identifying a 4.3L Vortec-csfiengine.jpg
Old Dec 15, 2012 | 11:09 PM
Curtis Hieb's Avatar
Curtis Hieb is on a distinguished road
From the looks of it, I'd almost guess the older engine looks nicer haha
Old Dec 16, 2012 | 06:35 AM
Captain, To the best of my knowledge, not a single 95 year Blazer came with the SCFI engine shown in the second picture. The SCFI engine came out in the 96 Blazer.
The difference between the cut off points in the 95 Blazer engines that makes the interchange messy is the ignition system as the early engine used with the full OBD1 ECU didn't have a crank position sensor. So if it looks like the top picture & doesn't have a CKP sensor, the engine could be used in anything from a 93 to an early OBD1 95.
If it has the CKP sensor and looks like the first picture, then it can be used for an OBD1.5 or OBD2 95. I believe you can use the "updated CPI" in anything back to a 93 with a distributor swap to the old style and just ignore the CKP sensor, but that might also require a swap of the intake manifolds as somewhere in the span from 93-95 GM changed from vacuum powered EGR valves to electronic and I think the mounting is different (I very well could be wrong on this as I have never actually looked at it myself).
If it looks like the second picture, then it would be 96+. If it has a stamped steel oil pan, 96 to sometime in 97. Cast aluminum pan, it could be a late 97 to end of production.
Old Dec 18, 2012 | 05:44 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Actualy the mid or late 95 year CPI engine also has has the aluminum oil pan.
Old Dec 18, 2012 | 07:22 PM
RetroBlazer's Avatar
RetroBlazer will become famous soon enough
I think the engine code is on the block on a pad in front of the passenger side head. I can look up the engine code.
Old Dec 18, 2012 | 08:47 PM
Correct it is there.
smurphy132
Jan 28, 2010 07:11 AM
Radical_MT
Oct 22, 2008 10:39 AM
sdhk
Sep 22, 2008 07:26 PM
punxweb
Sep 18, 2008 12:19 PM
fnirish
14
Aug 25, 2007 08:53 PM
