I'm relieved yet apprehensive
I had the problem with the SES for "coolant below thermostat temp" and had a low reading temp gauge in the instrument cluster so I changed the thermostat and lo and behold the temp on the dash gauge is reading about 3-4 ticks higher and I noticed that the blazer is shifting better and what appears to be less often. During the thermostat change I disconnected the battery for around 40 minutes but when I put it back and fired up the blazer the SES was still on. I figured to do the PCT this comingweekend as the next possible fix. Well today after about 3 days and around 100 miles after the thermostat change(is one of those significant??) the SES goes out. It still shows up when I turn the key on so I know the light is good. What's the deal, did it just heal itself or can I expect this to rear its ugly head again? Any information would be appreciated.
Thanks
Thanks
RE: I'm relieved yet apprehensive
Not all codes are reset with a battery disconnect. You basically put it through a drive cycle which cleared the codes.
Thanks swartllk guess I won't be waiting to the shoe to drop.
Glad to hear you got it fixed.
Glad to hear you got it fixed and that it wont rear its ugly head again!!!
miso
13
01-02-2007 10:20 AM
