Intake gasket
Old Nov 4, 2008 | 06:47 PM
badwrench's Avatar
badwrench is an unknown quantity at this point
Default Intake gasket
92 4.3 with CPI
The new intake manifold gaskets Ibought does not have the rear ports blocked off like the old ones do.Willthey work ok?
Thanks
Old Nov 4, 2008 | 07:05 PM
Default RE: Intake gasket
If I remember correctly, there is not a cross over in the rear of the lower manifold, but it has been an awful long time since I have had off the manifold of the older CPI motors... Anyway, if that is the case, then there is no reason why the gasket would need to have the rear port blocked off as there would be no place for the coolant to go anyhow.
Old Nov 5, 2008 | 03:54 PM
Hanr3's Avatar
What Swart said.
Intake manifold doesn;t ahve anywhere for the coolant to go, however you do need to seal both sides of the gasket around those openings so the coolant doesn't travelto other parts of the engine.
limited edition 1
Jan 27, 2023 11:07 AM
Melrock83
Jul 3, 2012 06:51 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
