Lost Easy-out in transmission
Old May 28, 2014 | 12:19 PM
nehlert22's Avatar
nehlert22 is on a distinguished road
Default Lost Easy-out in transmission
I have a '96 4x4 blazer that just had one of the bolts on the starter brake off. I was centering the easy-out punch on the bolt to punch the center when it slipped out of my fingers and in to the hole the starter goes in to. So now the easy-out is at the bottom of what I believe is part of the transmission. There is a ,what looks like, circular metal plug. Is there away to take that out and fish the easy-out from there? Any other suggestion to get it out?
Old May 28, 2014 | 12:43 PM
EZEARL's Avatar
EZEARL is on a distinguished road
My '96 is missing that metal plate which should just pop out. Don't know about our trans but some also have an inspection plate across the bottom front of the bellhousing you may be able to remove.
Old May 28, 2014 | 12:46 PM
newguy's Avatar
What Earl said, get under there and look around
Old Jun 1, 2014 | 09:05 PM
Tranzman's Avatar
Tranzman is on a distinguished road
96 and newer s series have a removable stamped steel plug in the bell housing. just pop it out with a straight blade screw driver and fish around with a flexible magnet. If you get a left hand drill bit from a tool place it should pull the broken bolt out as you drill. Righty tighty lefty loosy!!! We used to do it all the time at the chevy dealer. super fast and the average parts store will have the new bolt.
Tranzman
gitch93
Nov 27, 2012 10:37 PM
rastoma
Nov 2, 2009 07:04 PM
kurslt
Oct 14, 2009 06:21 PM
deadgoon20
Oct 30, 2008 02:03 PM
Vermilion
Suspension Tech
Jul 23, 2007 11:39 PM
