MAF Sensor
Old Oct 29, 2017 | 06:31 AM
GreenBlazer2002's Avatar
Default MAF Sensor
Quick question-
If I unplug the MAF sensor, should the engine cut off? Tried it for a test and it made little difference in the idle.
The reason I did it is I'm having a p0101 issue I'm trying to track down.
Thanks in advance for y'alls input.
Old Oct 29, 2017 | 11:46 AM
LesMyer's Avatar
https://blazerforum.com/forum/diagno...plained-31561/
See the diagnostic charts in this link. You will need a scanner and a multimeter to diagnose your MAF sensor.
Last edited by LesMyer; Oct 29, 2017 at 04:33 PM. Reason: MAF sensor, not MAP sensor.
Old Oct 29, 2017 | 03:30 PM
See the diagnostic charts in this link. You will need a scanner, a multimeter, and a hand vacuum pump to diagnose your MAP sensor.
I scoured the search function on here and never came across that link. Thanks man!
Old Oct 29, 2017 | 04:29 PM
LesMyer's Avatar
You're welcome. A lot of good info there. FYI you can't access it unless you are logged in.
chevy lady
Aug 29, 2007 10:17 AM
N1ZZN
May 14, 2006 12:08 PM
khalid_20879
Mar 27, 2006 11:16 AM
MikeForS
Mar 25, 2006 04:43 PM
ivannj
Feb 11, 2006 03:00 PM
