new distirbutor, blue smoke engine turned backwards
Old Mar 27, 2009 | 12:07 AM
bodhifirestarr's Avatar
bodhifirestarr is on a distinguished road
I will give this a go in the morning and then get back to you.
Old Mar 27, 2009 | 01:37 AM
WolfPack's Avatar
I still dont see how the engine will start, then go in reverse..
Old Mar 27, 2009 | 07:07 AM
Yeah, that is very strange. A small movement in reverse I can see (and have) as a cylinder comes up on a compression stroke and then rolls backwards, relieving the pressure, but not for a few seconds...
Old Mar 28, 2009 | 04:27 PM
Originally Posted by swartlkk
A small movement in reverse I can see (and have) as a cylinder comes up on a compression stroke and then rolls backwards, relieving the pressure...
I guess is the better choice of words. I did follow the directions per the DYI(EDI Engine Timing) and it seems fine now. I guess I must have been off a tooth or two. Funny thing though about the new distributor I received for RockAuto, it didn't have the white paint mark on it, so I used the old distributor for a guide. It seems to be ok now, running that is. I am going to check it again in a little while to make sure, but I was wondering if I was off a tooth or two or more, should it have started in the first place. It just seems odd to me, that it would start and then the next day have the blue smoke, and the pressure release, I guess you called it. Wouldn't it have done it to start with?
medea1993
Jun 7, 2012 12:29 PM
LinuxWindows
Apr 15, 2012 11:33 AM
hondacharger
Jun 14, 2010 01:47 PM
1979K5
May 4, 2010 09:33 AM
speakerwire
Oct 7, 2008 07:21 PM
