New Tranny Question
Old Oct 9, 2007 | 08:45 PM
gocartone's Avatar
gocartone is an unknown quantity at this point
Default New Tranny Question
I was wondering if anyone knew a good place to get arebuilt transmission. Looking for the cheapestI can find, around $600-900. What transmissions would fit? I have been looking on ebay andI'm not sure if all 4l60Es fit. I have a 2001 4x4 blazer. Thanks for any help!
Old Oct 10, 2007 | 03:05 PM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
Default RE: New Tranny Question
I think all the 4L60E's should fit. But if you are unsure you could probably call some junkyards and they could give you a list of vehicles that identical ones would be in.
Old Oct 10, 2007 | 03:14 PM
Not all 4L60E's are created equal. Some had a 2 peice case and others had a 3 peice case. I believe there is a post around here somewhere that detailed the year cut-offs for the different case designs. Ah, there it is. In '98 they changed to a bolt on bell housing. The transmission length also changed by a 1/2" between the pre-98 4L60E's and the 98+ 4L60E's.
So you'll need a 4L60E with a 3 piece case from a 98+ 4x4 truck. If you find one out of a fullsize truck with the 3 piece case, these transmissions will have a few extra clutches for the v8 applications so they should handle a bit more abuse.
Old Oct 10, 2007 | 05:40 PM
gocartone's Avatar
ORIGINAL: swartlkk
Alright thanks for the help!
ski.dive
Feb 7, 2014 05:18 AM
Logan
Jan 21, 2010 09:07 PM
xtreme03
Engine & Internal
Sep 30, 2006 06:25 PM
tomsblazer
Aug 21, 2006 01:01 PM
jagblazer01
Mar 1, 2006 10:29 PM
