Oil leak at oil cooler (or radiator)
Old 11-27-2015, 09:00 PM
Squatcher's Avatar
Squatcher is on a distinguished road
Default Oil leak at oil cooler (or radiator)
Ok, need a little help here, just wondering if anyone has had any problems will the engine oil cooler lines leaking. My lower line on my 2001 4x4 blazer seems to be leaking, or is it possible for the radiator to leak oil. The reason I ask is after replacing lines and o rings it is still leaking. Does anyone no if the radiator could be leaking oil.
Old 12-05-2015, 04:31 PM
Toocute350's Avatar
Toocute350 is on a distinguished road
Where exactly is the oil coming from?Is it coming from the radiator area, or the engine area?
Old 12-05-2015, 08:36 PM
Squatcher's Avatar
Drivers side bottom at radiator.
Old 12-05-2015, 09:09 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Well, if you replaced all 4 lines with new ones, then I think one of these three conditions exist:
1) You have hole in your radiator's oil cooler
2) You got a defective line
3) Installation of the lines didn't go so well. Make sure that the fittings that screw into the radiator are tight, and make sure the oil cooler lines are pushed all the way into those fittings with those safety clips installed...
Hope that helps!
Old 12-05-2015, 09:12 PM
Squatcher's Avatar
Thank you for your help. So your saying the radiator can leak oil because that's what it looks like to me.
Old 12-05-2015, 09:18 PM
CWBDDSPC's Avatar
Yep, the oil lines that go into and out of the radiator carry oil into a little cooling deal in the radiator. You can remove the lines and pressure test it.
Old 12-05-2015, 09:19 PM
Squatcher's Avatar
Ok thank you
Old 04-09-2024, 09:08 PM
Jaime510's Avatar
Jaime510 is on a distinguished road
​​Hello I know this post is old but how does one pressure test the radiator to determine if the oil cooler is leaking inside?
Damato
02-14-2015 03:28 PM
MWS1994
05-12-2014 03:26 AM
Impact
07-19-2013 09:42 AM
NYC86ZC
12-12-2010 08:21 AM
Jetfixer
07-11-2006 05:02 AM
Quick Reply: Oil leak at oil cooler (or radiator)
