oil line help
Old Sep 28, 2007 | 04:39 PM
dueve20's Avatar
dueve20 is an unknown quantity at this point
Default oil line help
got old one out but i had to cut it out its the line the goes from the oil filter to the engin block and i cant fit the new one in any ideas
Old Sep 28, 2007 | 06:52 PM
Default RE: oil line help
You may need to jack the motor slightly to open up enough room to get the flange over the front differential. I know mine were a pain to get in and it took me quite a bit of time to do. The other piece of advice I can give is to have the bolt in there when you slide the flange back to the filter adapter on the back/side of the engine. I used 2 12" extensions and a shallow 10mm socket and kept the socket on the bolt while I slide everything into place. Also, make sure that the new gasket piece stays on while you slide it in. After that, it is pretty much all by feel... I was able to position my magnetic mechanics mirror so that I could see up to where everything went which helped out greatly.
chris015
Apr 8, 2012 02:12 PM
ohsofly
Oct 27, 2010 06:52 PM
hotrod413
Aug 3, 2009 05:08 PM
fondo
Nov 16, 2008 03:11 PM
todaresqSL2
Nov 10, 2008 01:47 PM
