Popping sound coming from engine
Old Jun 17, 2008 | 06:30 PM
orangeshamrock's Avatar
orangeshamrock is an unknown quantity at this point
Default Popping sound coming from engine
I recently just blew the radiatior, had that replaced as well as thermostat and lines. Flush and replace fluids.
The day after I got it back, the Service Engine Soon came on, I took it to the local autozone to check the code and it said it was the MAF Sensor. The following day the Service engine light went out. This evening it has come back on, and there is a popping sound coming from under the hood/engine. Seems to be a little loss of power. Air condioner works as it normally does, however, when popping the hood to look for the sound I noticed that the compressor will stop spinning, then start up again. Is that normal? and what is making the popping sound?
Old Jun 17, 2008 | 07:56 PM
pbishop's Avatar
pbishop is an unknown quantity at this point
Default RE: Popping sound coming from engine
The a/c compressor will stop and start, that is normal, but the check engine usually isnt normal and a popping sound either, i would get it checked out.
abarone7411
Oct 18, 2014 07:05 PM
Peel01
Jul 24, 2010 10:46 PM
johnroe2727
Dec 6, 2009 05:45 PM
grendragginbu
Jan 26, 2007 03:04 AM
Mike
Aug 23, 2005 11:49 AM
