Proper spider injector
Old Mar 28, 2019 | 01:37 PM
Trukntigger's Avatar
Yea, just ordered one other day, arrives friday- I purchased this one for my upgrade.
Shows complete kit.
Old Mar 28, 2019 | 06:16 PM
cleburne red's Avatar
You guys with your 96+ trucks suck! I'm stuck over here replacing sucky factory stock with more sucky factory stock
Old Mar 29, 2019 | 12:41 AM
Oh come on, you know soon as a good reason comes alone you will be finding a decent boneyard engine 96+ for your ride and be right in with the rest of us. Heck I mentioned before, only reason I got 98 was wanted 4 wheel disc which is stock on 98+
Old Mar 29, 2019 | 08:19 PM
Close! When the good reason comes along, I'll be finding a nice 350 to put in there! Or maybe a 5.3L LS, if I really feel like spending a ton of money!
Old Mar 7, 2022 | 05:03 PM
Dragonfire78's Avatar
Dragonfire78 is on a distinguished road
What year did you get yours from i went and loom at a 2003 wuth x in the vin took it all a part and it still had the old style in it😭not sure what year they changed styles in them
Old Mar 7, 2022 | 07:31 PM
Been awhile but reading back old style 96-02 not sure if production change occur mid year at that point. Still drive my 98, 220,000 miles plus been doing great with hardly a problem, last trouble I had was a bad left rear caliper. Heck I dragged a double axle Uhaul trailer 600 plus miles in December without a issue. Motor fine, occasion misfire code found plug wire loose and ok. You looking at right version of injector? Newer has wires for tips at each port being the giveaway when looking. Keep in mind on used prior owner may have used old style due to cost or availability or such seeing either setup would work.
Old Mar 7, 2022 | 09:08 PM
Yea I was looking for the newer ones with wires at the end. Of the tips. I want the newer style google said 2003 blazer witch x in the vin should be all ready newer style and its only one them junk yard had in that year. They sell some newer ones on ebay but there china ones lol so not sure how good they are
Old Mar 7, 2022 | 09:29 PM
I’d recommend the Delco official part in this case if possible. With gasket kit and work involved you don’t want to repeat the repair anytime soon. Scroll back several post will see one I bought via Amazon in 2019, was complete and shows part number. If you search you will also see post I did with photos and the issues I dealt with when replacing them. Some members tips proved very useful like making 4 of the old manifold bolts into guides for putting back together, lined up perfect for the liquid gasket section. Only replaced after diagnostic with scan tool via Bluetooth and app (iPad) showed leaking by measuring fuel rails. That ODB port tool was a great investment and still get to use it now and then. Good luck. Do a good job, it will last.
Search for you…if curious this read will be helpful maybe, fun nonetheless. https://blazerforum.com/forum/2nd-ge...s-99266/page2/ copy pasted so scroll to top, I posted quite a few pics doing this job on injectors
Jefflego
Jan 17, 2023 02:34 PM
rockjock29bc
83
Aug 1, 2019 07:26 PM
PuckinBlazer
Aug 12, 2017 08:39 AM
614blazer
22
Dec 17, 2013 04:10 PM
kaynos
Aug 1, 2011 11:42 AM
