Red shop rag sucked into engine
Old 01-04-2013 | 02:30 PM
jmatson's Avatar
jmatson is on a distinguished road
Default Red shop rag sucked into engine
Please enjoy a good laugh. I took my 87 blazer to a shop to have a new carb installed. (to lazy to do it) he put a reg shop rag in the intake. He fired it up. Running like **** knocking. He blamed the knocking on the starter fluid being used. After it started to idle still knocking. I noticed rag fibers coming out the exhaust. Killed it. Left. Was told they would Tare it down. Get there today with mu new water pump and can expected to see the engine in parts. To find out its running. They didn't pull anything apart to inspect. Ran it to burn the rag out.
The truck is still there. What kind of damage we might be seeing.
Thinking valves or maybe a rod
Old 01-04-2013 | 02:32 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
i dont think it would hurt to much if they burned it out
Old 01-04-2013 | 02:33 PM
Banned
this is one reason i use paper towels instead of rags.
Old 01-04-2013 | 02:35 PM
jmatson's Avatar
Keyword much. Ya I use those blue paper towels also.
Heading there now. For a meeting. It was the manager that did the work. The fun thing the work was done by a auto shop on a Airforce base so had to go above few heads
Old 01-04-2013 | 02:40 PM
warthogdriver's Avatar
when i was building my stang engine i almost bolted down the lower intake with a rag in there..luckily i saw the corner of the rag when i checked for final alignment. i almost had a heart attack.
if it were their engine and someone did that they would be upset...
Old 01-04-2013 | 02:48 PM
grizzstang's Avatar
grizzstang is on a distinguished road
I think my biggest fear would be a bent valve. I would demand a compression test (done at their expense with you watching) to rule out any immediate issues.
Old 01-04-2013 | 02:56 PM
jmatson's Avatar
150-180 psi good range. Don't know how engine was built.
Old 01-04-2013 | 03:29 PM
jmatson's Avatar
Compression test 150 psi on all 8
rexazz2
10-19-2013 09:34 PM
tycobb280
08-09-2013 09:09 AM
Toby Hanson
04-20-2013 03:49 AM
blue_zr2
Lifting Tech
06-14-2011 01:17 AM
95_4door
12-28-2008 11:13 PM
