rough idle
rough idle
1995 blazer, 4.3 , 4x4, idles real rough. runs ok on the road. hasnt died yet at idle , but has come close. smells rich , i replaced the computer. still the same ????????????????
Test your fuel pressure. Specifically watch it after the pump shuts off.
It is very likely that you have a fuel leak internal to the intake plenum.
fuel press. is within rec. factory specs. i was woundering about the E G R valve ?
The EGR is another possibility. Remove, clean, and reinstall with a new gasket. Preferably one with a screened inlet.
blazerguy22
11-14-2013 11:50 PM
97BLAZE4X4
02-07-2010 07:33 PM
