rough idle plz help
Old Dec 6, 2013 | 11:12 PM
Cherk's Avatar
Cherk is on a distinguished road
Default rough idle plz help
My 2000 Blazer 4.3L began this problem a week ago. I have since replaced the following with no luck: Distibutor cap and rotor, spark plugs and wires, and spider injector. I have done some research and possibilities are vacuum leak and/or fuel pump. Above about 30 mph it runs fine but slower speeds cause sputter and very sloppy acceleration. I'd much appreciate any advice!
Old Dec 7, 2013 | 12:24 PM
Diaita's Avatar
Have you done a fuel pressure test?
Old Dec 8, 2013 | 10:15 PM
Cherk's Avatar
Yes I checked fuel pressure yesterday. If I remember correct, on filter was 88psi and only dropped to 60 after 10 minutes. I also connected it under the hood and although I don't remember the numbers, I know the pressure was good and held. Today I cleaned the MAF sensor and Idle air control valve which reduced the roughness but didn't eliminate it. My SES doesn't flash anymore! Lol oh.. I have been getting P0300 code since it started. Thanks for your reply I hope to hear more!
Old Dec 17, 2013 | 12:31 AM
Cherk's Avatar
Have been busy with maintenance for a week! Ran a compression check and cylinder 6 had no, I repeat, zero pressure.. with no previos valve/cylinder experience, I dove headfirst and pulled out what I believe people call the head. To find that the smaller valve on the said cylinder 6 is bent and cannot close all the way. Thank god it wasn't worse. Thanks for everyone that posted, you were so much help.............................................. ............................... *cricket*
Old Dec 17, 2013 | 12:55 AM
Cherk's Avatar
Just some questions for reinstallment.. 133000 miles on 2000 blazer and found a bent valve. Should I replace head? I don't wanna go through the procedure again so any advice as to simply replace the valve or go for the whole head. I'm not usually a smartass like last post, I just thought this site would be more helpful.
Old Dec 17, 2013 | 03:59 AM
newguy's Avatar
we usually are, just happens sometimes. I wouldnt replace head. If it aint broke, dont fix it
Old Dec 17, 2013 | 01:56 PM
Diaita's Avatar
Sorry man, I'm not around on weekends, or if it's busy at work. Gunna be honest, BF doesn't pay well enough to be here 24-7. Who do I hit up for a raise...or any money?
Old Dec 18, 2013 | 10:50 PM
Cherk's Avatar
Ok so no new head, but the bent valve damaged the piston a bit. Not a hole in it by any means but there is definitely damage. Wondering if that will effect anything? I really appreciate your guys' inputs I'm pretty new at this
Old Dec 19, 2013 | 12:08 AM
Cherk's Avatar
also need to know the chance of this happening again. to me it seemed like the valve and piston only collided once or twice. so i'm choosing to rule out a timing issue, I hope it was just stuck from being heavily coated in carbon.
blazerguy22
Nov 14, 2013 11:50 PM
Chevrolet.Love
Aug 19, 2011 09:05 PM
nhguy261
Dec 30, 2010 01:41 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
c10jm
Aug 12, 2008 05:34 PM
