Rough start
Old Oct 16, 2007 | 03:48 PM
bradgfp0084's Avatar
bradgfp0084 is an unknown quantity at this point
Default Rough start
When I start the the engine, the whole truck shakes really hard but after the start it is fine. HELLLLPPP!!!
Old Oct 17, 2007 | 01:09 PM
Hanr3's Avatar
Default RE: Rough start
Does the shaking go away after you give it gas?
Sounds like it starving for fuel during start up. Turn the key to run, but not start for a second, then turn it too start and see if that makes a difference.
Old Oct 17, 2007 | 01:58 PM
rriddle3's Avatar
Another idea...Have you checked the motor and transmission mounts to make sure they are not broken?
Old Oct 18, 2007 | 08:24 AM
Yeah the it only shakes when I start it then it is fine. I've tried just turning the key on for a second then starting and it acts the same. I will be checking the engine and motor mounts now though. I've thought of that but I thought if it was the mounts it would shake while at high speeds as well.
Old Oct 18, 2007 | 08:33 AM
rriddle3's Avatar
ORIGINAL: bradgfp0084
...I've thought of that but I thought if it was the mounts it would shake while at high speeds as well.
Perhaps, but not necessarily. I've had cars with broken mounts that only showed symptoms at start-up or engine revving while in 'park'.
Old Jan 5, 2010 | 06:07 PM
pshaw54's Avatar
pshaw54 is on a distinguished road
I know its old, but what was the solution? i'm having the same problem, rough at startup, check engine light comes on; sometimes it smooths out after a few seconds, sometimes longer. thanks!
Old Jan 5, 2010 | 07:27 PM
The CEL is trying to tell you something...
And why would you dig up a 2+ year old thread that has no resolutions posted in it when there are more than a few other threads discussing this topic and similar ones with trouble shooting steps, etc...
Old Jan 5, 2010 | 11:33 PM
pshaw54's Avatar
because this just happened to be the exact problems that im facing. i saw similar, but not exact problems in other threads. figured it was easier to resurrect and old one as opposed to starting a new one.
any answers?
RandyRhoadsFan82
Mar 29, 2014 11:22 AM
blazerguy22
Nov 14, 2013 11:50 PM
nhguy261
Dec 30, 2010 01:41 PM
c10jm
Aug 12, 2008 05:34 PM
CringeSchrapnel
Nov 17, 2006 05:32 PM
