s10 jerking/surging
Old 12-02-2010, 05:08 PM
All of those issues can be caused by a problem with the VSS (vehicle speed sensor). Whether it is just dirty or is failing or maybe there is a wiring problem between the PCM and the VSS.
Old 12-02-2010, 06:43 PM
stevo's Avatar
stevo is an unknown quantity at this point
well ive replaced the vss the last time it did this with no solution
today i completely cleaned every ground i could find
and also put on my stock winter wheels
and it looks like its fixed.
could be my larger tires on my chrome wheels setting it off
Old 12-02-2010, 08:34 PM
Rims shouldn't affect the VSS readings.
Old 12-03-2010, 01:53 PM
stevo's Avatar
sorry i should have clarified
different sized tires will set it off correct?
the back were like 29 inches tall and the fronts were 26
Old 12-03-2010, 03:56 PM
It might potentially be the cause for the ABS/brake/etc light, but it shouldn't affect the speedometer.
techboy89
15
12-21-2017 04:20 PM
linegtdt52
13
02-27-2012 08:23 PM
Darbylives
03-20-2011 01:01 PM
gr8s10
11-10-2009 06:27 PM
caddy500
10-02-2009 11:23 PM
Quick Reply: s10 jerking/surging
