Sea foam
Old Oct 24, 2013 | 11:37 PM
charliebrown's Avatar
charliebrown is on a distinguished road
Default Sea foam
HI,I am running some sea foam thru fuel system and it was suggested to leave old filter in fuel line to catch any garbage in fuel system before putting on new filter.
I am also thinking about using a bottle to catch what might be in fuel lines
by cycling fuel pump to get anything that might just before new fuel filter
any thoughts on this would be appreciated,thanks
Old Oct 25, 2013 | 02:47 AM
newguy's Avatar
I would just put it in the tank and run a tank fuul then change the filter. Seafoam does its work when its just sitting
Old Oct 25, 2013 | 06:54 PM
ol' grouch's Avatar
ol' grouch is on a distinguished road
I've used Sea Foam in really nasty systems. It will clean things out pretty well. The only thing I haven't seen it do is get into heavily clogged idle passages in carburetors. It can really fill up a fuel filter with gooky stuff (<---------fancy technical term) and stop it up. By keeping the old filter in there, you're filling up what you plan to throw away anyway. This way, when you put a new filter on, it should last a while as most of the garbage went with the old one.
Old Nov 21, 2015 | 01:56 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Old Jun 23, 2018 | 05:27 PM
TonyZR2's Avatar
TonyZR2 is an unknown quantity at this point
Sea Foam right now at NAPA is $7.99 CAN.!!! Never seen it that low.
1985BlazerS10
Sep 13, 2019 10:24 PM
spittybays
Sep 26, 2012 11:47 AM
classklown90
Sep 3, 2009 10:53 PM
klenderb
Dec 25, 2007 09:06 PM
hyperionmax2003
Nov 11, 2007 02:21 AM
