seafoam
Old Sep 14, 2011 | 11:33 PM
84BlazerS10's Avatar
I have used seafoam in my truck quite a few times great product. But my engine seems to stall out as soon as you pour it down the carb but have never had any problems with it not starting back up.
Old Sep 15, 2011 | 04:23 PM
chvyblazer00's Avatar
chvyblazer00 is on a distinguished road
yea im prob gonna get the spray kind and try it that way. it might of been that clean bc i did an intake about 5 thousand miles ago and the intake was nasty with carbon all over it and i cleaned it all back to metal but i was sure there was more carbon everywhere but i dunno, it did make it run butter tho so i guess ill just leave it at that for now
Old Nov 19, 2015 | 02:29 PM
syfaz777's Avatar
syfaz777 is on a distinguished road
i have a 1999 blazer 4.3vortec . i just put 4 ounces of seafoam in the oil crankcase. drove it around for 15 miles and noticed the idle is smoother i thought my engine was off it was so smooth. i checked the dipstick after and the oil didn't turn super dark yet. but we will see what color it turns after 100 miles then i will do a oil change. the reason why i tried this is because my oil pressure seems kind of higher than normal and the engine would give off a bad smoke smell under the hood when the engine is cold . maybe its my pcv valve . we will see if it goes away because i never had this problem before and the burning smell goes away when the oil pressure lowers a bit when the engine warms up. my theory is the engine is dirty inside or the pcv valve is not working correctly to vent the combustion gases inside the crankcase or valve covers. maybe someone can give me some advice
Old Nov 21, 2015 | 08:06 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
I wouldn`t do it.That`s just my opinion.After you do this procedure..I would clean the spark plugs.They will be fouled out after it`s all said and done.This would be a good time to replace your plugs while your at it, if you didn`t already replace them.If you do decide to replace them.Take a look at the (Torque Master)spark plugs @extreme spark.com.I had these on my 81 chevy malibu 350 5.7 liter 11yrs until I sold her.You don`t have to worry about gapping and regapping them.It`s not made like a regular plug.They are kind of pricey..$11.00 a piece plus $9.00 flat shipping charge.I have them on my ride as we speak.
Old Dec 18, 2017 | 01:03 AM
02eXtreme402's Avatar
02eXtreme402 is on a distinguished road
so i used it today and i didnt have the results everyone else has. i poured 1/3 in the tank and turned on my truck poured about 1/3 down the brake booster vac line and shut off the truck, waited 20 mins turned it back on and it didnt smoke at all. should i try using more in it? i hear your not suppose to have it stall out your truck. so idk, maybe its just that clean inside? but i doubt it cause it has 146k on it, so idk what i did wrong
I guess he should have looked how old this was before replying but going the brake booster route with the 4.3 doesn't work the best, it only gets the back 2 pistons, you need to get the spray can and go straight into the intake. I did the same thing on my 95 Sonoma. Was like holy crap this motor is clean!! After reading more I realized i had done it wrong... 🤣😂😐
VRDriver4l
Engine & Internal
13
Jan 2, 2007 04:36 PM
geekdagr8
May 8, 2006 11:04 PM
dion21379
Mar 27, 2006 04:10 PM
tomsblazer
Feb 4, 2006 08:56 PM
khalid_20879
Jan 3, 2006 04:07 PM
