swapping motor and transmission
The transmission probably will. The engine, however, will not. '95 == CPI engine. '96 == SCFI engine. While the block can likely be used from a '96 into a '95, the heads on up are different and would need to be swapped from the '95 engine.
Wrong again. The bolts that hold the intake manifold to the heads are in a different orientation (96+ SCFI engine has vertical bolt orientation while the 95 & earlier CPI engines had the intake bolts oriented perpendicular to the intake gasket surface on the head.
N3ROST4R
Aug 27, 2012 11:01 PM
white95blazer
Aug 25, 2010 08:44 PM
nimblestix
Jun 29, 2010 01:03 PM
