swapping motor and transmission
Old Jun 8, 2011 | 01:24 AM
gtridle's Avatar
gtridle is on a distinguished road
Default swapping motor and transmission
Just wondering if a 96 blazer motor and tyranny would work in a 95 GMC jimmy
Old Jun 14, 2011 | 08:03 PM
skyzmine's Avatar
skyzmine is on a distinguished road
yes it will
Old Jun 14, 2011 | 08:14 PM
The transmission probably will. The engine, however, will not. '95 == CPI engine. '96 == SCFI engine. While the block can likely be used from a '96 into a '95, the heads on up are different and would need to be swapped from the '95 engine.
Old Jun 15, 2011 | 05:40 PM
skyzmine's Avatar
just have to swap intakes. it will fit and work.
Old Jun 15, 2011 | 05:52 PM
Wrong again. The bolts that hold the intake manifold to the heads are in a different orientation (96+ SCFI engine has vertical bolt orientation while the 95 & earlier CPI engines had the intake bolts oriented perpendicular to the intake gasket surface on the head.
N3ROST4R
Aug 27, 2012 11:01 PM
white95blazer
Aug 25, 2010 08:44 PM
nimblestix
Jun 29, 2010 01:03 PM
bigeasy
Nov 28, 2008 07:25 PM
grovecdn
May 12, 2008 06:45 AM
