Throttle cable adjustment?
Old May 30, 2012 | 10:17 AM
redneck44244's Avatar
redneck44244 is on a distinguished road
Default Throttle cable adjustment?
i didnt have much luck looking on the fourm for this, i noticed the other day that my throttle cable on my 01 blazer had a lot of slack in it and when i had a friend push my pedal all the way to the floor i found that my throttle blade was only open about 80 percent (i could still pull my throttle open a little more by hand). i looked around my throttle body and pedal and couldnt see anything that looked like an adjuster, so if there is a way to adjust this cable tighter) please let me know.
Old May 30, 2012 | 11:07 AM
It doesn't look like there is any adjustment...
You could try moving the bracket out away from the front of the throttle body by swapping it's position on the special bolt/stud that holds it there. Or possibly adding something to the cable between the cable end & the throttle pedal to take up the slack.
Old May 30, 2012 | 02:30 PM
i kinda had a feeling i was gona have to make something up hah, i was just wondering though because they have an adjuster on the cruise control cable so i was just wondering, ill post if im able to make something decent work.
natebocek
Aug 16, 2017 10:02 PM
Squad-6
Apr 22, 2013 02:19 PM
bret
Feb 11, 2010 05:58 PM
t.lyttle
May 24, 2009 01:37 PM
ChrisAttebery
Jul 3, 2007 12:31 PM
