Tranny Cooler
Old Apr 30, 2018 | 02:22 PM
David Thomas's Avatar
David Thomas is on a distinguished road
Default Tranny Cooler
Previous owner cut the line to my transmission cooler and I'm needing a schematic or picture of the locations and connections of the hoses so I can install new lines. Also is the transmission cooler needed, it came with one so I would think it is. If anyone has any pictures of the hose connections and routing of the lines, please post those.
Old May 1, 2018 | 07:11 AM
Hi and welcome to the blazerforum.
Now we would just need to know what vehicle you need that info for.
Make, Model, Year, Transmission, 4WD or 2WD, and if the trans cooler is the engine radiator heat exchanger or a separate one.
Old May 1, 2018 | 01:36 PM
Rusty Nuts's Avatar
You're right Mr. Thomas. The cooler a transmission runs the longer it lasts. I'd check the transmission to engine bolts and the whole area to see if the transmission has been replaced. Most cases when the transmission scatters the cooler becomes unusable from contamination. If it were mine I'd get an aftermarket cooler kit. I use local store hayden kits and haven't had to use the lifetime warranty yet.
robjamber
Feb 1, 2010 10:20 PM
gizwilly
Engine & Internal
Feb 20, 2007 10:52 PM
AutomagicLS1
Engine & Internal
Dec 5, 2006 06:32 PM
Jetfixer
Jul 11, 2006 05:02 AM
herskal
May 26, 2006 11:46 PM
