Tranny Cooler question
Old May 14, 2014 | 05:53 PM
jmparker82's Avatar
jmparker82 is on a distinguished road
Default Tranny Cooler question
I have a 2000 Blazer LT 4x4 with th 4L60E tranny. I am putting an aftermaket tranny cooler on it. Will it be better to just run the aftermarket tranny cooler and disconnect the factory one. Or run the aftermarket tranny cooler after the factory cooler as a add on?
I live in North Dakota so the winter temps is why i am asking. The tranny uses Dex VI so it is synthetic so it doesn't thicken or thin like coventional oil. Any suggestions would be appreciated especially if you live where it gets -30 out.
Old May 14, 2014 | 06:53 PM
richphotos's Avatar
Most people have used both the factory and after market.
Old May 14, 2014 | 07:26 PM
rexazz2's Avatar
Always a good idea to run in conjunction with radiator
In colder weather you can over cool the fluid
IIRC the install instructions should recommend the fluid passing threw aux cooler >> radiator >> then transmission
that routing should keep the ATF close to water temperature
Old May 14, 2014 | 09:10 PM
jmparker82's Avatar
Thank You for the input. I am definitely keeping the radiator cooler connected then.
robjamber
Feb 1, 2010 10:20 PM
smoke03
Jun 30, 2009 02:18 AM
AutomagicLS1
Engine & Internal
Dec 5, 2006 06:32 PM
Jetfixer
Jul 11, 2006 05:02 AM
herskal
May 26, 2006 11:46 PM
