tranny swap
Old Feb 26, 2009 | 12:12 PM
mjd808's Avatar
mjd808 is an unknown quantity at this point
Default tranny swap
I have a 99 Blazer with the auto 4wd option. Can I swap the transmission from a 97 that doesn't have the auto 4wd?
Old Feb 26, 2009 | 12:24 PM
Default RE: tranny swap
One difference on the transmission side of things is that the 97 may or may not have had a two piece main transmission case (removable bell housing) and you 99 definitely has a two piece main case. The bolt pattern on the back of the transmission may also be different (square 4 bolt pattern vs the hex 6 bolt pattern your 99 has). You have to check and see. Other than that, the transfer case used has nothing to do with the transmission.
Old Feb 26, 2009 | 09:25 PM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
the output shaft on the 2wd is longer then on the 2wd so you can use it only if you swap the shafts out which means taking the tranny apart....
ski.dive
Feb 7, 2014 05:18 AM
middleman496
Aug 7, 2007 07:53 AM
oldsledman
Apr 6, 2007 05:29 PM
91 Streeter
Engine & Internal
Feb 1, 2007 10:56 AM
KA3AX
Apr 1, 2006 11:53 AM
