Trans won't upshift, No Reverse?????
Old Oct 29, 2007 | 10:07 PM
jjimmy's Avatar
jjimmy is an unknown quantity at this point
Default Trans won't upshift, No Reverse?????
I have a 98 blazer 4.3, 4x4, auto, 4door, 72K. I have owned this truck for about3 months and its been trouble free. I bought it with 66K this thing is a cream puff still has the windo sticker and original sales recept in the glove box. No issuses, except for a hard 1-2 shift which was not of a real concern. I was driving down the road tonight 30-35 mph and heard a whinging servo type noise from under the truck followed by a clunk. It all sounded much like the 4x4 shift motor, as i stoped and started at the next light i found that the trans was holding first until i let off the gas and then banged into 2nd. also i no longer have reverse, i found that out after i pulled in a down sloping parking spot.Now when i put it in drive it holds fristand revs up to 4500rpm and wont shift to 2nd unless i let off the gas. does any one have any idea what this is and how to fix it??. Ive already replaced a trans in my wifes 2000 jimmy and I realy dont want to have to go through that horror again even with a lift, air tools, a trany jack and an oxi torch its not fun.
thanks Noah
Old Oct 31, 2007 | 02:28 AM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
Default RE: Trans won't upshift, No Reverse?????
I would suggest doing a tranny fluid change. When you drain the tranny if it is full of metal flakes you probably need a new tranny.
Old Nov 2, 2007 | 10:58 PM
Johnkoch's Avatar
Johnkoch is an unknown quantity at this point
I was thinking the linkage but that weouldnt cause it not to go into second,so my advice would be to take it to a shop to get checked out.
Old Nov 3, 2007 | 04:01 PM
DHAL's Avatar
DHAL is an unknown quantity at this point
is a service engine light on
Old Nov 7, 2007 | 10:36 AM
blzr00/209's Avatar
blzr00/209 is an unknown quantity at this point
EXACTsame thing just happed to me. '00 4x4 LT (117.7K). Needed new transmission. Happened without any warning.
Left it at the dealership and just got the GM certified replacement. 36mo/50K warantee. As a widow, I have always just
taken my car to the small town dealership a couple blocks from my house. I like to keep cars a long time I usually figure
at least $1K per year at this point in time.
My problem is the gas gaugeworked fine when I left it at the dealership. They said when they moved it inside, the fuel gauge
was no longer working. I know that it was just over 1/2 tank when I dropped it off. Any ideas whatcould have
happed to the gauge in that short amount of time?
Old Nov 8, 2007 | 04:43 PM
ride4life's Avatar
ride4life is an unknown quantity at this point
I GOT AUSED TRANSMISSION W/96K FOR YOU 450 PLUS SHIPPING
91blazerlifted
Mar 6, 2012 04:09 PM
ludvigsen08
Aug 29, 2010 02:42 PM
moldeck
Nov 23, 2009 05:57 PM
1986k5blazer
May 26, 2009 06:54 PM
bjasonpowell
Jan 22, 2009 12:18 PM
