Transmission or solenoids?
Old Jul 28, 2020 | 05:47 PM
Goldtrimbravada's Avatar
Goldtrimbravada is on a distinguished road
Default Transmission or solenoids?
I have a 1997 bravada with 227k recently I notice a lag when I accelerate also when I would go from park to reverse or drive I would feel a clunk. Today as soon as I got on the highway it was running ok then traffic came to a stop and as soon as I started to accelerate it took very long for the gear to kick in and the service light started to blink. Now me reverse is out and I only got 2 gears not sure which ones but it’s take while to change gears. Need help pin pointing the problem I would like to k ok if it’s the solenoids or the transmission Also I was getting a loud grinding noise up front before all this started
Old Jul 28, 2020 | 06:08 PM
First off, did you check the transmission fluid level?
When you check if it is full, also check the color and smell. If it is burned looking or smelling then there was likely damage to the transmission.
Take it to a auto parts store and have them use their OBD reader to check for codes.
Old Jul 28, 2020 | 06:30 PM
yea i checked the fluid and it seem fine and i just went to autozone to check for codes and the only codes that came up were for the fuel injectors and intake manifold gasket codes. nothing for the transmission.
Old Jul 29, 2020 | 12:36 PM
Transman304's Avatar
Sounds very much like a stripped reaction shell. Very common on these units.
1st and 3rd only, no 2,4 or R: Sunshell is fractured or splines are sheared off.
And here it is, the short list of common problems with the 4L60E Transmission and repair:
  • Slow, slipping or no reverse.
  • Shifting is delayed.
  • Loud bang or grinding noises
Hess13x
May 3, 2020 07:32 PM
Megamatt
Jul 2, 2019 05:55 PM
upmaine
Jul 14, 2012 01:03 PM
199634
Apr 20, 2011 02:09 PM
hemivette
May 21, 2010 08:04 PM
