trouble pumping gas
Old Sep 1, 2011 | 03:50 PM
pellie0's Avatar
pellie0 is on a distinguished road
Default trouble pumping gas
I have a 2001 zr2 blazer. just staring today im unable to put more then a couple gallons of gas into the tank before the pump shuts off. i have read that over filling can cause back up pressure. i filled it up about a week ago and this is the first time i have tried to fill up since then. i dont think i put too much in last time, just stopped pumping when the pump stopped (didn't top off). also as a side note i recently have changed the pressure valve on the fuel pump. any thoughts?
Old Sep 1, 2011 | 03:56 PM
pettyfog's Avatar
Did you try a different gas pump?
Old Sep 1, 2011 | 04:48 PM
Frog's Avatar
Frog is on a distinguished road
LOL!!! That is what I would try first too, or just try re-positioning the fuel dispenser some are kinda picky.
Then if that does not work, I would look into a possible plugged/restricted tank vent. Did you get a fairly decent amount of air rushing out of the tank when you removed the gas cap??
kennybopaloo
May 24, 2012 05:16 PM
94tahoe95lt
Jan 28, 2012 01:55 PM
degaine_designs
Aug 19, 2009 11:12 PM
awaywilli
Nov 5, 2008 01:00 PM
SnowRemorse
Jan 4, 2008 11:26 AM
