u joint replacment
Old May 4, 2013 | 04:48 PM
swanman35's Avatar
swanman35 is on a distinguished road
Default u joint replacment
1999 blazer 2 door 4 wheel drive. Well since I've owned the blazer tjere has been a clunking when going into drive and reverse. I suspect the u joints need replacing. Now, I've searched around but haven't found anything that helps much. How would i go about doinh this?
Old May 4, 2013 | 08:03 PM
rexazz2's Avatar
all ujoints I have ever done I cut the old ujoint cross in half with a cutting torch
Ujoint caps are held in place by plastic injection around the caps
The heat from cutting usually melts the plastic that was holding the old caps in place
Knock the old caps out being carefull to not bend the yokes of the shaft
I press the new caps in usually using the bench vice again carefull of the yokes making sure all the neddle bearings stay in place
Some of the loan a tool places have ujoint/balljoint presses instead of using a vice
Old May 4, 2013 | 08:16 PM
50lb_cat's Avatar
There are some good videos on youtube.
Old May 5, 2013 | 09:19 AM
swanman35's Avatar
Very detailed. Thank you. I'll check out some videos too
josemateos
Feb 18, 2014 10:00 AM
Guntheone
Dec 4, 2010 05:59 PM
toxikchevy
Engine & Internal
Jan 26, 2010 04:27 PM
blazerboy30
Nov 20, 2007 11:27 PM
chevys rule
Jun 10, 2007 10:26 AM
