Vacuum line swelling
Old Sep 4, 2019 | 02:28 PM
03jawja's Avatar
Default Vacuum line swelling
My vacuum line coming off of the engine to the check valve/ vacuum t is swelling, i.think it started after I got trans flushed or changed pcv valve
Old Sep 5, 2019 | 05:47 AM
Can you post a picture of that hose and maybe the swelling?
Old Sep 5, 2019 | 06:26 AM
03jawja's Avatar
Error I will do.it as soon as I get back to shop, I did forget to say it's very oily on the outside
Old Sep 5, 2019 | 11:27 AM
What year is your Blazer? Assuming it is 4wd and has the 3-button controlled 4wd system, it sounds like it could be transmission fluid coming up from the transfer case. I heard of this happening but not after a transmission flush.
Old Sep 5, 2019 | 02:03 PM
03jawja's Avatar
Here are pics..changing today while I change engine oil...also will put on a clamp also.
Old Sep 5, 2019 | 05:23 PM
03jawja's Avatar
I changed it today with a high temp vacuum line from work. It pretty slipped right off as soon as I touched it. It was engine oil in the swelled line, I cleaned other line and check valve with sea foam.
The line going to the canister was also loose. I took Christine's advice and zip tied the lines snug. I put a clamp on the one that connected to engine. Happy to say after I replaced pcv valve a month ago i realized i have no oil residue in intake anymore. I noticed on my drive that my ac was cooler during idle. My idle was also more steady, didnt have that small 100 rpm jump it was having now during stop and go traffic.
Old Sep 6, 2019 | 01:08 PM
Good you could fix it. On some rubber or plastic products engine oil can do this swelling.
Old Sep 6, 2019 | 01:33 PM
03jawja's Avatar
I'm thinking about a catch can
Red9Beard4
Aug 30, 2022 05:48 PM
man0steel
14
Aug 10, 2018 07:52 AM
Miket919
Jan 21, 2012 12:57 PM
shawn95
Engine & Internal
Nov 23, 2010 06:35 AM
dusted800
Nov 17, 2006 06:32 PM
