Whats the difference between Sonnax .490 boost valve and Transgo .500 boost valve?
Old Dec 12, 2010 | 01:09 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
Default Whats the difference between Sonnax .490 boost valve and Transgo .500 boost valve?
I know there is an advertised .010" inch differnce between the two, but is there any other difference between the two? and which is better for a stock transmission with some wear on it? and does one give more line pressure than the other? and does it affect idle line pressure too? i appreciate any info or advice , thanks
Old Dec 12, 2010 | 02:56 PM
The stock boost valve is 0.470" in diameter. Both the Sonnax and the Transgo valves will increase line pressure. Sonnax states a 10-15% increase in line pressure. I wasn't able to find the increase for the Transgo valve.
Old Dec 16, 2010 | 12:27 PM
hi Kyle, would you know if these boost valves will boost line pressure at idle too? or only as the rpm or throttle increases? only because i dont want high line pressure at idle because then i will have a hard engagement. and would the .500 boost more than the .490 since its bigger ?
Old Dec 16, 2010 | 04:28 PM
I'm not sure on idle line pressure, but I would assume so.
It also stands to reason that the .500 boost valve would increase the line pressure more than the 0.490 boost valve.
bigdaddykane93
14
May 8, 2014 08:54 AM
Chevy33
Mar 25, 2012 11:52 AM
Dturner14
Mar 20, 2008 09:23 PM
nofear17bmx
Aug 3, 2007 11:24 PM
Pugsley
Feb 2, 2006 10:08 AM
