Will this fluid work for the transfer case
Old Jul 12, 2021 | 10:02 PM
CODEE_'s Avatar
CODEE_ is on a distinguished road
Default Will this fluid work for the transfer case
Will this Valvoline fluid work in our transfer case ? Mines a 4wd 4 button it says it works with autotrak 2 systems.im worried cause I'm doing u joints and if I lose any fluid I Wana top up. Also my vehicle has 168000km should I drank and refill the t case ?
Old Jul 13, 2021 | 08:30 AM
Yes, that fluid will work. You won't lose a ton of fluid when you remove the rear driveshaft, but some will come out. If it hasn't been changed in a long time (or ever), this might be a good opportunity to drain it all out and refill it with new.
Old Jul 17, 2021 | 11:42 PM
RedValor's Avatar
RedValor is on a distinguished road
ACDelco also makes an AutoTrak II fluid. I use that in my 4-door auto transfer case and I use regular Dexron III in my ZR2 for the 3-button "InstaTrak" model as described in the service manual.
Bolbol
Mar 30, 2016 03:39 PM
motoart1
Apr 12, 2011 07:09 PM
raymondrobinson
Mar 27, 2010 08:09 AM
whoareyou4
Aug 12, 2009 03:12 PM
Driveby
Nov 8, 2007 06:56 AM
