wont start!:( help please
Old Feb 23, 2013 | 02:33 PM
warthogdriver's Avatar
you shouldnt need any scan tool to do first fire up. i never had to when i did my lim gasket. also (should be similar) when i finally fired up my mustang for the first time after rebuild i didnt use any special tools. i just found TDC and then aligned the cam sensor and away i went.
if you find TDC and then follow then inst for the dist you should be fine. also check youtube it may help you to see it done.
good luck
Old Feb 23, 2013 | 02:52 PM
swanman35's Avatar
swanman35 is on a distinguished road
I believe I messed up somewhere cause it stillu doesn't start. I'm just gonna have the local mechanic look at it, he said he thinks it timing so I'll have him fix it. I don't think It'll cost too much.
Old Feb 27, 2013 | 10:02 PM
swanman35's Avatar
I forgot to update. I got it timed properly and is running well. Was a lot easier then i was making it. I do need to change plugs,cap,and rotor. I cracked my cap when screwing it on, but it'll wait till Friday. My plug for #1 got stripped somehow, so it is kinda loose and ticks unless I pusj it in with my hand, so now that I need 1 changed I might as well do the others. So Friday = oil change(to make sure no coolant is in it from the LIM gasket change), and all new plugs, etc.
welderman85
Jan 10, 2014 10:06 PM
1992S10blazer4.3
Jan 29, 2010 08:35 PM
jimmy979
Oct 11, 2009 06:28 PM
00blazerLS
17
Jul 6, 2008 07:44 PM
scottyk
Mar 14, 2007 09:54 PM
